Salta al contenuto principale
Royal Kludge GK64 Keyboard Switch Spring Replacement
Cosa ti serve
  1. Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: passo 1, immagine 1 di 2 Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: passo 1, immagine 2 di 2
    • Use a keycap remover to pull your keycap up and off of the keyboard.
    • Remove any keycaps surrounding the one you are working on if you need more space.
  2. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 2, immagine 1 di 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 2, immagine 2 di 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 2, immagine 3 di 3
    • Use the switch puller to pull the desired switch out of your keyboard.
  3. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 3, immagine 1 di 2 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 3, immagine 2 di 2
    • Place your switch onto your switch opener, and gently push down.
    • Make sure the switch is securely in place and continue to remove the top housing.
  4. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 4, immagine 1 di 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 4, immagine 2 di 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 4, immagine 3 di 3
    • Use the stem holder to remove the stem, which will reveal the switch spring.
    • Remove the switch spring.
  5. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 5, immagine 1 di 2 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 5, immagine 2 di 2
    • Align your new spring with the center of the bottom housing and gently place the switch spring.
  6. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 6, immagine 1 di 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 6, immagine 2 di 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 6, immagine 3 di 3
    • To put the stem back, align the stem legs with the metal plate on the switch.
    • Remove the switch from the switch opener.
    • Gently push down onto the housing until you hear a click and both pieces are into place.
  7. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 7, immagine 1 di 2 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 7, immagine 2 di 2
    • Align the pins located at the bottom of the switch to the corresponding pin holes in the keyboard.
    • Gently push the switch back into the keyboard.
  8. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 8, immagine 1 di 1
    • Place the keycap back onto the switch and push down to secure the keycap.
Conclusione
Diksha Sakre
Membro da: 09/19/22
228 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 603
