Salta al contenuto principale
Rowenta Focus Power Assembly Replacement
Cosa ti serve
  1. Rowenta Focus Power Assembly Replacement, Power Assembly: passo 1, immagine 1 di 2 Rowenta Focus Power Assembly Replacement, Power Assembly: passo 1, immagine 2 di 2
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
  2. Rowenta Focus Power Assembly Replacement: passo 2, immagine 1 di 3 Rowenta Focus Power Assembly Replacement: passo 2, immagine 2 di 3 Rowenta Focus Power Assembly Replacement: passo 2, immagine 3 di 3
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
  3. Rowenta Focus Power Assembly Replacement: passo 3, immagine 1 di 2 Rowenta Focus Power Assembly Replacement: passo 3, immagine 2 di 2
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
  4. Rowenta Focus Power Assembly Replacement: passo 4, immagine 1 di 2 Rowenta Focus Power Assembly Replacement: passo 4, immagine 2 di 2
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
  5. Rowenta Focus Power Assembly Replacement: passo 5, immagine 1 di 3 Rowenta Focus Power Assembly Replacement: passo 5, immagine 2 di 3 Rowenta Focus Power Assembly Replacement: passo 5, immagine 3 di 3
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
Conclusione
To reassemble your device with new power supply, follow these instructions in reverse order.
Altre 3 persone hanno completato questa guida.
1Commento della guida
Thanks... Where we can get parts
Baiju Vasavan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 106
Tutti i Tempi: 7,506
