Introduzione
The material setting knob on the Rowenta Focus DW5080 controls the amount of steam and heat used based on the specific material being ironed. If this button becomes stuck or is not changing the steam amount, the knob needs to be replaced following this replacement guide.
Prior to beginning this repair, the iron must be off and cooled down to avoid burns.
Cosa ti serve
Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
Lift out the piece.
Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
Using the T20 screwdriver, remove both of the 20mm screws on the underside of the iron.
