Salta al contenuto principale
Rowenta Focus Heating Element and Soleplate Replacement
Cosa ti serve
  1. Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: passo 1, immagine 1 di 2 Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: passo 1, immagine 2 di 2
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
  2. Rowenta Focus Heating Element and Soleplate Replacement: passo 2, immagine 1 di 3 Rowenta Focus Heating Element and Soleplate Replacement: passo 2, immagine 2 di 3 Rowenta Focus Heating Element and Soleplate Replacement: passo 2, immagine 3 di 3
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
  3. Rowenta Focus Heating Element and Soleplate Replacement: passo 3, immagine 1 di 2 Rowenta Focus Heating Element and Soleplate Replacement: passo 3, immagine 2 di 2
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
  4. Rowenta Focus Heating Element and Soleplate Replacement: passo 4, immagine 1 di 2 Rowenta Focus Heating Element and Soleplate Replacement: passo 4, immagine 2 di 2
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
  5. Rowenta Focus Heating Element and Soleplate Replacement: passo 5, immagine 1 di 3 Rowenta Focus Heating Element and Soleplate Replacement: passo 5, immagine 2 di 3 Rowenta Focus Heating Element and Soleplate Replacement: passo 5, immagine 3 di 3
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
  6. Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: passo 6, immagine 1 di 3 Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: passo 6, immagine 2 di 3 Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: passo 6, immagine 3 di 3
    • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
    • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
    • Lift out the piece.
  7. Rowenta Focus Heating Element and Soleplate Replacement: passo 7, immagine 1 di 3 Rowenta Focus Heating Element and Soleplate Replacement: passo 7, immagine 2 di 3 Rowenta Focus Heating Element and Soleplate Replacement: passo 7, immagine 3 di 3
    • Replace with an identical part by inserting it into the space.
  8. Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: passo 8, immagine 1 di 2 Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: passo 8, immagine 2 di 2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
  9. Rowenta Focus Heating Element and Soleplate Replacement: passo 9, immagine 1 di 2 Rowenta Focus Heating Element and Soleplate Replacement: passo 9, immagine 2 di 2
    • Unhook the clips on the top of the metal piece.
    • Using the metal spudger, remove the metal piece on the tip of the iron.
  10. Rowenta Focus Heating Element and Soleplate Replacement: passo 10, immagine 1 di 2 Rowenta Focus Heating Element and Soleplate Replacement: passo 10, immagine 2 di 2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
  11. Rowenta Focus Heating Element and Soleplate Replacement: passo 11, immagine 1 di 3 Rowenta Focus Heating Element and Soleplate Replacement: passo 11, immagine 2 di 3 Rowenta Focus Heating Element and Soleplate Replacement: passo 11, immagine 3 di 3
    • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
  12. Rowenta Focus Heating Element and Soleplate Replacement: passo 12, immagine 1 di 3 Rowenta Focus Heating Element and Soleplate Replacement: passo 12, immagine 2 di 3 Rowenta Focus Heating Element and Soleplate Replacement: passo 12, immagine 3 di 3
    • Lift the iron up using the handle to completely detach the soleplate.
Conclusione
Altre 4 persone hanno completato questa guida.
1Commento della guida
hi how do i clean sole plate inside ??????????????????? wath sort of sealent do they use to seal it or where do you get it from????????????????
Willie Waldner - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 144
Tutti i Tempi: 5,760
