Salta al contenuto principale
RotoZip Rebel REB01 Type 2 Power Cord Replacement
Cosa ti serve
  1. RotoZip Rebel REB01 Type 2 Power Cord Replacement, Saw Casing: passo 1, immagine 1 di 1
    • Unplug the saw before attempting any of the replacement guides.
    • Orient the saw so that the handle is closest to you and the saw end points towards the left.
  2. RotoZip Rebel REB01 Type 2 Power Cord Replacement: passo 2, immagine 1 di 2 RotoZip Rebel REB01 Type 2 Power Cord Replacement: passo 2, immagine 2 di 2
    • Push down on the grey lock on the right side of the handle to unlock it.
    • Pull the handle to detach it from the saw.
  3. RotoZip Rebel REB01 Type 2 Power Cord Replacement: passo 3, immagine 1 di 2 RotoZip Rebel REB01 Type 2 Power Cord Replacement: passo 3, immagine 2 di 2
    • Lift the black lock at the tip of the saw to unlock the depth gauge.
    • Pull the depth gauge to detach it from the saw.
  4. RotoZip Rebel REB01 Type 2 Power Cord Replacement: passo 4, immagine 1 di 1
    • Rotate the device so that the bottom of the saw is facing upwards.
    • Remove the six 20mm screws with a 6mm flathead screwdriver.
  5. RotoZip Rebel REB01 Type 2 Power Cord Replacement: passo 5, immagine 1 di 2 RotoZip Rebel REB01 Type 2 Power Cord Replacement: passo 5, immagine 2 di 2
    • Cut through the stickers on the right and left sides of the saw using a metal spudger.
    • Pull off the top half of the casing.
  6. RotoZip Rebel REB01 Type 2 Power Cord Replacement, Power Cord: passo 6, immagine 1 di 2 RotoZip Rebel REB01 Type 2 Power Cord Replacement, Power Cord: passo 6, immagine 2 di 2
    • Remove the two 14 mm screws on the plastic plate holding the power cord with a flat head screwdriver.
    • Lift off the plastic plate holding the power cord with a tweezer.
  7. RotoZip Rebel REB01 Type 2 Power Cord Replacement: passo 7, immagine 1 di 1
    • Pull the switchboard out slowly.
    • The power switch will also come out. Set it on the side.
  8. RotoZip Rebel REB01 Type 2 Power Cord Replacement: passo 8, immagine 1 di 2 RotoZip Rebel REB01 Type 2 Power Cord Replacement: passo 8, immagine 2 di 2
    • Pinch the two white clips with your thumb while simultaneously removing the black and white wires.
    • Remove the power cord from the saw.
    • When reassembling, make sure to plug the black wire into the top clip.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 4-4, Livingston Fall 2016 Membro di Cal Poly, Team 4-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 601
