Salta al contenuto principale
Rotary Multi Selector Wheel Removal
Cosa ti serve
  1. Rotary Multi Selector Wheel Removal, Back Cover Removal: passo 1, immagine 1 di 3 Rotary Multi Selector Wheel Removal, Back Cover Removal: passo 1, immagine 2 di 3 Rotary Multi Selector Wheel Removal, Back Cover Removal: passo 1, immagine 3 di 3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  2. Rotary Multi Selector Wheel Removal: passo 2, immagine 1 di 1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  3. Rotary Multi Selector Wheel Removal, Detaching Ribbon: passo 3, immagine 1 di 2 Rotary Multi Selector Wheel Removal, Detaching Ribbon: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  4. Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: passo 4, immagine 1 di 3 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: passo 4, immagine 2 di 3 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: passo 4, immagine 3 di 3
    • Lift up the metal cover and its button slowly using the tweezers.
Conclusione
Andrew Lau
Membro da: 04/18/13
1 Reputazione
1 Guida realizzata
Cal Poly, Team 8-56, Johann Spring 2013 Membro di Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 601
