Introduzione
This is a guide explaining how to take the side buttons on the Rosewill NEON M62 mouse off. This repair should be performed if the side buttons to the mouse are visually broken or the bottoms do not respond when clicked.
Cosa ti serve
Place the mouse so the bottom is facing upwards.
Remove the plastic skates.
Remove the two 5 mm screws with a Phillips #00 screwdriver.
Hold the top half of the mouse with your non-dominant hand.
With your dominant hand, push an opening tool into the gaps in the panel.
Pry the panel off.
Using the opening tool, take the mouse 1 and mouse 2 buttons off the top of the mouse.
