Salta al contenuto principale
Rosewill NEON M62 Bottom Panel Replacement
Cosa ti serve
  1. Rosewill NEON M62 Bottom Panel Replacement, Bottom Panel: passo 1, immagine 1 di 1
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Bottom Panel Replacement: passo 2, immagine 1 di 1
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Bottom Panel Replacement: passo 3, immagine 1 di 2 Rosewill NEON M62 Bottom Panel Replacement: passo 3, immagine 2 di 2
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
Conclusione
Joshua Alves
Membro da: 03/16/23
97 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 106
