Salta al contenuto principale
Roku XD 2050X Remote Motherboard Replacement
Cosa ti serve
  1. Roku XD 2050X Remote Motherboard Replacement, Remote Control Casing: passo 1, immagine 1 di 2 Roku XD 2050X Remote Motherboard Replacement, Remote Control Casing: passo 1, immagine 2 di 2
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
  2. Roku XD 2050X Remote Motherboard Replacement: passo 2, immagine 1 di 2 Roku XD 2050X Remote Motherboard Replacement: passo 2, immagine 2 di 2
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
  3. Roku XD 2050X Remote Motherboard Replacement: passo 3, immagine 1 di 1
    • Gently use the spudger to pry the circuit board loose.
  4. Roku XD 2050X Remote Motherboard Replacement: passo 4, immagine 1 di 1
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
  5. Roku XD 2050X Remote Motherboard Replacement: passo 5, immagine 1 di 1
    • Using either end of the spudger, lift and remove the rubber keypad.
  6. Roku XD 2050X Remote Motherboard Replacement, Remote Motherboard: passo 6, immagine 1 di 1
    • Now that the remote is disassembled, you simply need to reassemble the remote using the replacement circuit board.
    • Be sure to dispose of the faulty circuit board properly. Recycle if possible!
Conclusione
To reassemble the remote once you've replaced the circuit board, return to the remote control disassembly page and follow the steps in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,025
