Salta al contenuto principale
Roku XD 2050X Motherboard Replacement
Cosa ti serve
  1. Roku XD 2050X Motherboard Replacement, Case: passo 1, immagine 1 di 3 Roku XD 2050X Motherboard Replacement, Case: passo 1, immagine 2 di 3 Roku XD 2050X Motherboard Replacement, Case: passo 1, immagine 3 di 3
    • Ensure the Roku XDis unplugged.
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Turn the device upside down.
    • Remove the two rubber pads using a plastic spudger.
  2. Roku XD 2050X Motherboard Replacement: passo 2, immagine 1 di 2 Roku XD 2050X Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the two Phillips #1 9mm pan-head screws.
  3. Roku XD 2050X Motherboard Replacement: passo 3, immagine 1 di 3 Roku XD 2050X Motherboard Replacement: passo 3, immagine 2 di 3 Roku XD 2050X Motherboard Replacement: passo 3, immagine 3 di 3
    • Insert spudger between upper and lower frame underneath the port access.
    • Guide spudger around to loosen upper and lower frame to pry frame apart.
    • Gently remove upper frame.
  4. Roku XD 2050X Motherboard Replacement: passo 4, immagine 1 di 2 Roku XD 2050X Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the two Phillips #1 8mm pan-head screws.
  5. Roku XD 2050X Motherboard Replacement: passo 5, immagine 1 di 1
    • On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
    • Lift the motherboard out of the lower frame.
  6. Roku XD 2050X Motherboard Replacement, Motherboard: passo 6, immagine 1 di 1
    • Replace the faulty motherboard with the new motherboard.
    • Be sure to dispose of the faulty motherboard properly. Recycle if possible!
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 4,937
