Salta al contenuto principale
Roku Streaming Stick Macro Button Contacts Replacement
Cosa ti serve
  1. Roku Streaming Stick Macro Button Contacts Replacement, Macro Button Contacts: passo 1, immagine 1 di 1
    • Place the remote so that the battery cover is facing upwards.
  2. Roku Streaming Stick Macro Button Contacts Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover to expose the battery compartment.
  3. Roku Streaming Stick Macro Button Contacts Replacement: passo 3, immagine 1 di 1
    • Remove batteries.
  4. Roku Streaming Stick Macro Button Contacts Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the 1.5 mm wide screw.
  5. Roku Streaming Stick Macro Button Contacts Replacement: passo 5, immagine 1 di 2 Roku Streaming Stick Macro Button Contacts Replacement: passo 5, immagine 2 di 2
    • Use a plastic opening tool to gently pry apart the plastic enclosure. Make sure you create a large enough gap before you attempt to separate the two pieces.
  6. Roku Streaming Stick Macro Button Contacts Replacement: passo 6, immagine 1 di 1
    • Gently remove the circuit board or motherboard.
  7. Roku Streaming Stick Macro Button Contacts Replacement: passo 7, immagine 1 di 1
    • First, gently remove the three plastic sheets. Then, remove the button panels from the remote control.
    • Repair the contact sheet as noted on the Button Contact Repair Kit listed above. Otherwise replace with new conductive button contacts.
Conclusione
Feliciano Bandazi
Membro da: 04/07/18
145 Reputazione
1 Guida realizzata
IUPUI, Team S2-G2, Wilson Spring 2018 Membro di IUPUI, Team S2-G2, Wilson Spring 2018
IUPUI-WILSON-S18S2G2
4 Membri
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,782
