Salta al contenuto principale
Roku 4 Ethernet Port Replacement
Cosa ti serve
  1. Roku 4 Ethernet Port Replacement, Motherboard: passo 1, immagine 1 di 1
    • Place the Roku 4 face-down on a table. The rubber sticker should be facing you.
  2. Roku 4 Ethernet Port Replacement: passo 2, immagine 1 di 1
    • Starting at one corner of the device, pull the rubber sticker back toward the opposite corner of the device carefully to reveal the underlying screws.
    • Completely remove the rubber sticker to reveal the underlying screws on the device.
    • Place the rubber sticker facing up on the table to preserve its adhesiveness. It will be needed to reassemble the device.
  3. Roku 4 Ethernet Port Replacement: passo 3, immagine 1 di 1
    • Turn the Phillips PH1 screwdriver counterclockwise to unscrew all 4 of the 12.0 mm screws.
    • Store the screws in a safe place, such as on a magnetic project mat, so they do not get lost before reassembly.
  4. Roku 4 Ethernet Port Replacement: passo 4, immagine 1 di 2 Roku 4 Ethernet Port Replacement: passo 4, immagine 2 di 2
    • Turn the device over so you can see the "4" on the top cover.
  5. Roku 4 Ethernet Port Replacement: passo 5, immagine 1 di 2 Roku 4 Ethernet Port Replacement: passo 5, immagine 2 di 2
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device and create a gap.
    • Prying open the device is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
  6. Roku 4 Ethernet Port Replacement: passo 6, immagine 1 di 1
    • After you have created a gap large enough to fit your fingers between, gently lift up the top cover to open the device and reveal the motherboard.
    • The motherboard should still be attached to the underside of the top cover by a red wire, a blue wire, and a black wire.
  7. Roku 4 Ethernet Port Replacement: passo 7, immagine 1 di 3 Roku 4 Ethernet Port Replacement: passo 7, immagine 2 di 3 Roku 4 Ethernet Port Replacement: passo 7, immagine 3 di 3
    • To begin removing the motherboard from the plastic casing, pinch the black plastic clip and gently pull upward.
    • Once you feel the motherboard begin to loosen from the plastic casing, pull it upward to remove it completely.
  8. Roku 4 Ethernet Port Replacement: passo 8, immagine 1 di 3 Roku 4 Ethernet Port Replacement: passo 8, immagine 2 di 3 Roku 4 Ethernet Port Replacement: passo 8, immagine 3 di 3
    • Peel back the black adhesive strip that attaches the blue wire to the motherboard.
    • Repeat this step for the strip that attaches the black and red wires to the motherboard.
  9. Roku 4 Ethernet Port Replacement: passo 9, immagine 1 di 3 Roku 4 Ethernet Port Replacement: passo 9, immagine 2 di 3 Roku 4 Ethernet Port Replacement: passo 9, immagine 3 di 3
    • Using a soldering iron, desolder the blue, red, and black wires from the motherboard.
    • Consult iFixit's Soldering Skills guide to safely use the soldering iron.
    • The motherboard should now be completely disconnected from the top cover of the device.
  10. Roku 4 Ethernet Port Replacement, Ethernet Port: passo 10, immagine 1 di 1
    • Lay the motherboard facedown on the table so you can see the large black ethernet port with several gold connections below it.
    • Use a soldering iron to desolder each of the ethernet port's connections to the motherboard.
    • Consult iFixit's Soldering Skills guide to learn how to safely use the soldering iron.
  11. Roku 4 Ethernet Port Replacement: passo 11, immagine 1 di 1
    • Using your thumb and pointer finger, carefully pinch the Ethernet port and pull it to the right, away from the motherboard, to remove it.
Conclusione
Baylor, Team S5-G4, Williams Spring 2017 Membro di Baylor, Team S5-G4, Williams Spring 2017
BU-WILLIAMS-S17S5G4
3 Membri
4 Guide realizzate
3 Commenti
Is that the HDMI port
cruzanbay45 - Replica
Is that the HDMI port on roku
where do you get the HDMI port for roku
mar plane - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,158
