Salta al contenuto principale
Roku 2 Case Replacement
Cosa ti serve
  1. Roku 2 Case Replacement, Case: passo 1, immagine 1 di 1
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • Note: It may take several heats, left for a minute at a time, to loosen the glue.
  2. Roku 2 Case Replacement: passo 2, immagine 1 di 1
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2 Case Replacement: passo 3, immagine 1 di 1
    • Use the 000 phillips to remove the screws found under all four of the rubber pads.
  4. Roku 2 Case Replacement: passo 4, immagine 1 di 1
    • Gently remove the under side of the device.
  5. Roku 2 Case Replacement: passo 5, immagine 1 di 1
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2 Case Replacement: passo 6, immagine 1 di 1
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2 Case Replacement: passo 7, immagine 1 di 1
    • Remove the board from the plastic enclosure and put the board into the replacement enclosure.
Conclusione
Eric Rawls
Membro da: 08/24/15
360 Reputazione
2 Guide realizzate
USF Tampa, Team 1-5, Sullivan Fall 2015 Membro di USF Tampa, Team 1-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G5
3 Membri
7 Guide realizzate
Un commento
cause mine get’s hot and it’s slow as !&&*
brian price - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 739
