Introduzione
If anything is wrong with the roconia Q6 lens this guide will help you fix any issues. The replacement of the lens is very quick and easy and can be used whether the lens is simply just dirty or having issues projecting images correctly. When working on lens replacement make sure the roconia is on a flat dry surface and handled carefully.
Cosa ti serve
Flip roconia over to access screws holding lens in place
Remove 7.9 mm screws using a Phillips #0 screwdriver
