Salta al contenuto principale
Rocketfish RF-WSP313 Speaker Replacement
Cosa ti serve
  1. Rocketfish RF-WSP313 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Using the metal spudger, remove the outer cap from the top of the device.
  2. Rocketfish RF-WSP313 Speaker Replacement: passo 2, immagine 1 di 1
    • Using a Phillips # 1 screwdriver, remove the four 1.1 cm flathead screws attaching the metal ring to the top of the device.
  3. Rocketfish RF-WSP313 Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the ring and set aside.
  4. Rocketfish RF-WSP313 Speaker Replacement: passo 4, immagine 1 di 1
    • Using the metal spudger, remove the cap from the bottom of the device.
  5. Rocketfish RF-WSP313 Speaker Replacement: passo 5, immagine 1 di 1
    • Using a Phillips # 1 screwdriver, remove the four 1.1 sm screws attaching the metal ring to the bottom of the device.
  6. Rocketfish RF-WSP313 Speaker Replacement: passo 6, immagine 1 di 1
  7. Rocketfish RF-WSP313 Speaker Replacement: passo 7, immagine 1 di 1
    • Using a Phillips # 1 screwdriver, remove the four 1 cm screws from the outside panel. You will do this for each panel; it does not matter which side you start with.
  8. Rocketfish RF-WSP313 Speaker Replacement: passo 8, immagine 1 di 1
    • Using the metal spudger, pry off the side panel. Repeat this step on the other side panel.
  9. Rocketfish RF-WSP313 Speaker Replacement: passo 9, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the four 1.1 cm flathead screws from the side of the device. Repeat this step on the other side of the device.
  10. Rocketfish RF-WSP313 Speaker Replacement: passo 10, immagine 1 di 2 Rocketfish RF-WSP313 Speaker Replacement: passo 10, immagine 2 di 2
    • Using the metal spudger, open the device.
  11. Rocketfish RF-WSP313 Speaker Replacement: passo 11, immagine 1 di 2 Rocketfish RF-WSP313 Speaker Replacement: passo 11, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using your fingers (or a pair of tweezers), disconnect the speaker cord from its socket.
  12. Rocketfish RF-WSP313 Speaker Replacement: passo 12, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the four 1.2 cm pan head screws surrounding the speaker.
  13. Rocketfish RF-WSP313 Speaker Replacement: passo 13, immagine 1 di 1
    • Remove the speaker from the device.
Conclusione
Kara Falknor
Membro da: 01/25/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 558
