Salta al contenuto principale
Roborock Q5 Pro: Laser Distance Sensor Replacement
Cosa ti serve
  1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: passo 1, immagine 1 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: passo 1, immagine 2 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: passo 1, immagine 3 di 3
    • Flip it on its head, then remove the dustbin.
  2. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bottom cover.: passo 2, immagine 1 di 2 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bottom cover.: passo 2, immagine 2 di 2
    • Remove the side brush using a PH2 screwdriver.
    • Remove the screws using a PH2 screwdriver.
    • Then, pull the bottom cover off.
  3. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: passo 3, immagine 1 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: passo 3, immagine 2 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: passo 3, immagine 3 di 3
    • Lift it up on the left.
    • Detach the connector by squeezing the release tab, then pull it out.
    • Do not simply yank the battery out. You will tear the connector off the motherboard.
  4. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper's lid.: passo 4, immagine 1 di 2 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper's lid.: passo 4, immagine 2 di 2
    • Remove the marked screws using a PH1 screwdriver.
    • Then simply lift the lid off.
  5. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper.: passo 5, immagine 1 di 2 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper.: passo 5, immagine 2 di 2
    • Flip the robot over.
    • Tilt the bumper forwards and move it upwards to remove it.
  6. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the side brush motor.: passo 6, immagine 1 di 1
    • Flip it back over.
    • Simply lift it out.
  7. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the chassis screws.: passo 7, immagine 1 di 1
    • Remove the marked screws using a PH2 screwdriver.
  8. Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: passo 8, immagine 1 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: passo 8, immagine 2 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: passo 8, immagine 3 di 3
    • The chassis will still be held together by a couple latches on the back.
    • Use a prying tool to get these apart before taking it apart.
  9. Roborock Q5 Pro: Laser Distance Sensor Replacement, Take it apart!: passo 9, immagine 1 di 2 Roborock Q5 Pro: Laser Distance Sensor Replacement, Take it apart!: passo 9, immagine 2 di 2
    • Flip it over and simply pull the chassis halves apart.
  10. Roborock Q5 Pro: Laser Distance Sensor Replacement, Screeeeeeews.: passo 10, immagine 1 di 1
    • Here are the screws organised by steps and type.
    • Use this if needed as a reference during reassembly.
  11. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: passo 11, immagine 1 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: passo 11, immagine 2 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: passo 11, immagine 3 di 3
    • Then, remove it.
  12. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: passo 12, immagine 1 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: passo 12, immagine 2 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: passo 12, immagine 3 di 3
    • Lift the LDS towards the right, then disconnect the connector.
    • If you're replacing the LDS, simply insert the new one and reassemble your device.
  13. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: passo 13, immagine 1 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: passo 13, immagine 2 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: passo 13, immagine 3 di 3
    • Remove the rubber band using some tweezers, forceps or your fingers.
    • Make sure to clean it. This one was quite dirty, which was causing the motor to seize.
    • Your robot may have a different iteration of the LDS, which has a cover over the rubber band section. In that case, please check: Roborock Q Revo: Laser Distance Sensor Replacement and skip to step 12.
  14. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: passo 14, immagine 1 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: passo 14, immagine 2 di 3 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: passo 14, immagine 3 di 3
    • Before removing the motor, flip it over and check whether it has a connector or is soldered directly onto the PCBA.
    • Remove the screws.
    • Now you can remove and replace the motor.
    • Your robot may have a different iteration of the LDS, which needs it's driving wheel removed before you can remove the screws. In that case, please check: Roborock Q Revo: Laser Distance Sensor Replacement and skip to step 12.
Conclusione
DegenFixer
Membro da: 09/18/24
5.081 Reputazione
24 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 18
Ultimi 7 Giorni: 82
Ultimi 30 Giorni: 449
Tutti i Tempi: 4,791
