Salta al contenuto principale
Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement
Cosa ti serve
  1. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, Open kettle base: passo 1, immagine 1 di 2 Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, Open kettle base: passo 1, immagine 2 di 2
    • Before you begin, be sure to unplug the kettle base.
    • Using Torx screwdriver, open kettle base and remove PCB
    • One can see the five contact rings. From inside they are: Live, Sensor +, Sensor -, Neutral, Ground
  2. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, High voltage gap potential problem: passo 2, immagine 1 di 1
    • The PCB is not conformally coated, so water splashing around the base can potentially enter and cause damage.
    • The design of the PCB is a bit unfortunate as the high voltage switching regulator is very close to the LDO and microcontroller.
    • Line input
    • Switching regulator
    • LDO and MCU
  3. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, High voltage gap problem (2): passo 3, immagine 1 di 1
    • Red circle: Isolation gap between 320VDC and 4.4VDC is about less than 1mm
    • Red arrow: Pulsed 320V (220VAC) switching regulator
    • Blue arrow: 4.4V LDO supply voltage for MCU
  4. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, Microcontroller replacement: passo 4, immagine 1 di 1
    • Using hot air, desolder the TSSOP16 microcontroller labeled "Y12"
    • Unfortunately I was not able to source the microcontroller allone yet. But I could order the entire board for 25€ which is better than nothing. Thank you Ritter
Conclusione
Thomas Widmaier
Membro da: 03/05/13
2.039 Reputazione
10 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.468 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 373
