Introduzione
This guide will show how to replace the motherboard of the Ring Video Doorbell Pro.
Cosa ti serve
Start by using the star-shaped end of the included Ring screwdriver to take out the 5 mm screw on the bottom of the device.
The next step is to remove the last four connections holding the motherboard in place.
To reassemble your device, insert the new motherboard and follow these instructions in reverse order.
Altre 8 persone hanno completato questa guida.
4 Commenti
A pig to get apart. Prying the case open needed a glaziers flexy putty knife or spark plug feeler gauge as a plastic pry tool is not man enough . Connectors fall apart as you try to disconnect. Battery, aerial and capacitor are all glued or taped together.
You don’t need to disconnect the ribbon cable in Step 10 unless you intend to remove the camera module, which is screwed to the motherboard so comes away with it
thank you very useful - question is i cannot fine a spare main board im after a ring pro mainboard - i open mine and looks like some of the parts are blowen its all green :) do you offer a repair service of main board ?
