Introduzione
In this guide, you will be shown how to take apart and replace the Housing unit of the Ring Video Doorbell step-by-step. You will need a Phillips screwdriver size PH00 and a Plastic Tool Opener.
Cosa ti serve
Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
Pry open the aluminium plate using the Plastic Opening Tool(s).
Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
Altre 3 persone hanno completato questa guida.
Un commento
Hey, do you know if Ring will provide you with replacement front housing? My casing has been damaged by an attempted theft :(
