Salta al contenuto principale
Ring Video Doorbell Speakers Replacement
Cosa ti serve
  1. Ring Video Doorbell  Speakers Replacement, Motherboard: passo 1, immagine 1 di 3 Ring Video Doorbell  Speakers Replacement, Motherboard: passo 1, immagine 2 di 3 Ring Video Doorbell  Speakers Replacement, Motherboard: passo 1, immagine 3 di 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1 mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell  Speakers Replacement: passo 2, immagine 1 di 3 Ring Video Doorbell  Speakers Replacement: passo 2, immagine 2 di 3 Ring Video Doorbell  Speakers Replacement: passo 2, immagine 3 di 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
  3. Ring Video Doorbell  Speakers Replacement: passo 3, immagine 1 di 3 Ring Video Doorbell  Speakers Replacement: passo 3, immagine 2 di 3 Ring Video Doorbell  Speakers Replacement: passo 3, immagine 3 di 3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
  4. Ring Video Doorbell  Speakers Replacement: passo 4, immagine 1 di 2 Ring Video Doorbell  Speakers Replacement: passo 4, immagine 2 di 2
    • Detach the upper part of the motherboard from the bottom, using your hands.
  5. Ring Video Doorbell  Speakers Replacement, Speakers: passo 5, immagine 1 di 1
    • Speakers are two small rectangles located above the button of the doorbell.
  6. Ring Video Doorbell  Speakers Replacement: passo 6, immagine 1 di 1
    • To remove the speakers pry each one out carefully with a plastic opening tool.
Conclusione
USF Tampa, Team S11-G5, Cheng Spring 2018 Membro di USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Membri
10 Guide realizzate
Un commento
Where does one get replacement speakers for the 88RG000FC100 ring doorbell?
Jeffrey Lang - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 35
Ultimi 30 Giorni: 94
Tutti i Tempi: 4,146
