Introduzione
This guide begins after completing the motherboard replacement guide. All you will need for speaker replacement is a plastic opening tool. Speaker replacement may be needed if you are having sound issues.
Cosa ti serve
Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
Pry open the aluminium plate using the Plastic Opening Tool(s).
Remove the 2 1 mm screws using the PH00 Phillips Screwdriver.
Speakers are two small rectangles located above the button of the doorbell.
Un commento
Where does one get replacement speakers for the 88RG000FC100 ring doorbell?
