Salta al contenuto principale
Ring Stick Up Cam Camera Replacement
Cosa ti serve
  1. Ring Stick Up Cam Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the six 6mm Phillips #00 screws from the back of the device.
  2. Ring Stick Up Cam Camera Replacement: passo 2, immagine 1 di 1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Stick Up Cam Camera Replacement: passo 3, immagine 1 di 1
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
  4. Ring Stick Up Cam Camera Replacement: passo 4, immagine 1 di 1
    • Pry off the back cover using a plastic opening tool.
  5. Ring Stick Up Cam Camera Replacement: passo 5, immagine 1 di 1
    • Disconnect the battery power leads using a plastic opening tool.
  6. Ring Stick Up Cam Camera Replacement: passo 6, immagine 1 di 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  7. Ring Stick Up Cam Camera Replacement, Camera: passo 7, immagine 1 di 1
    • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
  8. Ring Stick Up Cam Camera Replacement: passo 8, immagine 1 di 1
    • Disconnect the ribbon connector shown in the photo.
  9. Ring Stick Up Cam Camera Replacement: passo 9, immagine 1 di 1
    • Remove the motherboard from the device by hand.
  10. Ring Stick Up Cam Camera Replacement: passo 10, immagine 1 di 1
    • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
    • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
  11. Ring Stick Up Cam Camera Replacement: passo 11, immagine 1 di 1
    • Remove the three plastic spacers shown in the photo by hand.
  12. Ring Stick Up Cam Camera Replacement: passo 12, immagine 1 di 1
    • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
  13. Ring Stick Up Cam Camera Replacement: passo 13, immagine 1 di 1
    • Lift the camera board out of the housing using your hand.
Conclusione
Ao Li
Membro da: 02/06/19
245 Reputazione
1 Guida realizzata
UC Davis, Team S18-G3, Lore Winter 2019 Membro di UC Davis, Team S18-G3, Lore Winter 2019
UCD-LORE-W19S18G3
3 Membri
8 Guide realizzate
2 Commenti
Where can I purchase a new lens?
Javier Casas - Replica
Any ideas where to get a new lens?
Mete Doguoglu - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 38
Tutti i Tempi: 4,593
