Salta al contenuto principale
Ring Stick Up Cam Battery Replacement
Cosa ti serve
  1. Ring Stick Up Cam Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the six 6mm Phillips #00 screws from the back of the device.
  2. Ring Stick Up Cam Battery Replacement: passo 2, immagine 1 di 1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Stick Up Cam Battery Replacement: passo 3, immagine 1 di 1
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
  4. Ring Stick Up Cam Battery Replacement: passo 4, immagine 1 di 1
    • Pry off the back cover using a plastic opening tool.
  5. Ring Stick Up Cam Battery Replacement: passo 5, immagine 1 di 1
    • Disconnect the battery power leads using a plastic opening tool.
  6. Ring Stick Up Cam Battery Replacement: passo 6, immagine 1 di 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
Conclusione
Altre 9 persone hanno completato questa guida.
UC Davis, Team S18-G3, Lore Winter 2019 Membro di UC Davis, Team S18-G3, Lore Winter 2019
UCD-LORE-W19S18G3
3 Membri
8 Guide realizzate
11 Commenti
Where can I get a replacement battery?
jbains - Replica
Bad news,
After three different calls to the Ring customer service line (just to be certain i was getting the true honest answer each time) i was told that the Ring stickup 1st generation cam - the one in this section is not available and never was. They suggest that this model was never intended yo be dissected as easy as we know it is. the best we can do is to find someone selling one with a damaged camera and removing its battery. That was how i was able to get my 1st gen stickup back in service again.
Dave S -
No reason to try this, no battery replacement? Have searched the Internet, can’t find a replacement!
Robert Byrum - Replica
Why would they not use the same simple replaceable battery system as the ring doorbell2
Peter Lasnick - Replica
Would love to replace the battery, if I could find it online…
Matthew Grow - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 101
Tutti i Tempi: 11,923
