Salta al contenuto principale
Ring Spotlight Cam Battery Lights Replacement
Cosa ti serve
  1. Ring Spotlight Cam Battery Lights Replacement, Lights: passo 1, immagine 1 di 1
    • Remove the top plastic pad by peeling it off with a metal spudger.
  2. Ring Spotlight Cam Battery Lights Replacement: passo 2, immagine 1 di 2 Ring Spotlight Cam Battery Lights Replacement: passo 2, immagine 2 di 2
    • Remove the 7 PH00 screws around the four corners with PH00 of the lid.
  3. Ring Spotlight Cam Battery Lights Replacement: passo 3, immagine 1 di 1
    • Use the metal spudger set to break the glue lining and the motion sensor will pop out.
Conclusione
Altre 6 persone hanno completato questa guida.
2 Commenti
this showed nothing about replacing the light bulb
Martha “purplemarty” Ewell - Replica
This is not a complete how to. The directions stop in the middle and don't show the replacement of the LEDs. Also no parts link for the replacement LED strips
Matt Newman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 91
Tutti i Tempi: 4,882
