Introduzione
Usa questa guida per rimuovere la Cover Superiore dalla tua PlayStation 3 Slim.
Cosa ti serve
Capovolgi la PS3 e poggiala sulla parte superiore.
Facendo attenzione, rimuovi l'adesivo di garanzia presente nella parte sottostante della console per trovare la copertura di una vite nascosta.
Rimuovi le 4 viti Torx da 13,3 mm sotto l'apertura del drive Blu-Ray (alcuni modelli possono avere solo 3 viti).
Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening.
Can we edit this to say 4 screws?
I made the change from three to four screws, but you're able to edit the guides as well. If you want to edit something, you can click the Edit link on the right side of any guide step, or the Edit link at the top right of the page (sandwiched in-between View and History).
Do you guys have a guide for the PS3 Slim Model 3001A. The fan is different than this model.
3001a is basically same motherboard but cheaper plastic bd drive other than that its exactly the same until you get to the new slim line
Robert -
My PS3 had only three Torx screws. Having four in the diagram was initially confusing. Obviously they made a mid-stream change at some point (mine is several years old now).
I've accidentally removed the ribbon cable from the blu-Ray drive and can not seem to figure out how to reconnect it. Can anyone help?
Take the top off the drive, connect the ribbon to the motherboard then replace the drive sliding the ribbon through the slot on the bottom of the drive and reconnect to the laser.
If the screw has a pin in the center, that means it is a security Torx meant to prevent tampering. To remove this screw, follow the guide I have linked below...
How do u buy the screw driver for these screws
Online at the usual suspects?
Or some hobby stores or places that sell tools will sometimes carry these.
Anyone else's screws for this step need the T7 bit instead of T8?
What is the name of this screwdriver
Solleva la cover superiore dal suo bordo posteriore e ruotala verso la parte anteriore della PS3 (dove presenti i tasti ON/OFF e EJECT}.
Rimuovi la cover superiore del PS3.
Per rimontare il tuo dispositivo, segui queste istruzioni in ordine inverso.
Altre 92 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
2 Commenti
No good mine a Sony.
Thank you this helped me so much!!!!
Don’t even need to bother with the sticker anymore since SONY does not care what you do with them anymore.
Travis Wheeler - Replica
