Introduzione
If you are not able to change the speed settings on your sander, the speed dial is probably at fault. The dial can become worn down, meaning that it needs to be replaced. Make sure that the sander is unplugged when completing this replacement.
Cosa ti serve
Remove the four M3.5 x 16 mm screws from the top cover using a Torx T10 screwdriver.
Quasi finito!
Conclusione
