Salta al contenuto principale
Ridgid JobMax R8620 Series E Drive Gear Cover Replacement
Cosa ti serve
  1. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement, Drive Gear Cover: passo 1, immagine 1 di 1
    • Pull the battery out of the case by hand before opening the device.
    • Using a Torx T10 screwdriver, remove the nine 6mm screws on the drill cover.
    • Lift off the outer casing.
  2. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: passo 2, immagine 1 di 1
    • After opening the cover, find the motor and pry it apart from the case in order to have space to do the replacement.
  3. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: passo 3, immagine 1 di 3 Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: passo 3, immagine 2 di 3 Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: passo 3, immagine 3 di 3
    • Find the gear cover.
    • Using a Phillips #0 screwdriver, remove the two screws on the plastic protective plate.
    • Remove the plastic plate.
  4. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: passo 4, immagine 1 di 2 Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: passo 4, immagine 2 di 2
    • Carefully pull off the gear cover.
Conclusione
Pengjian Zhou
Membro da: 02/06/19
557 Reputazione
4 Guide realizzate
UC Davis, Team S20-G1, Lore Winter 2019 Membro di UC Davis, Team S20-G1, Lore Winter 2019
UCD-LORE-W19S20G1
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 790
