Salta al contenuto principale
Ridgid GEN5X R8653 Base Assembly Replacement
Cosa ti serve
  1. Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: passo 1, immagine 1 di 3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: passo 1, immagine 2 di 3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: passo 1, immagine 3 di 3
    • Always disconnect battery and use gloves when working with the saw blade. Failure to do so may result in damage or injury!
    • Remove the supplied Allen wrench from it's nesting space in the front of the handle.
    • Depress and hold the spindle lock button located between the handle and blade shroud.
    • Using the supplied 6mm Allen Wrench, unscrew the bolt securing the blade and remove the blade.
  2. Ridgid GEN5X R8653 Base Assembly Replacement: passo 2, immagine 1 di 3 Ridgid GEN5X R8653 Base Assembly Replacement: passo 2, immagine 2 di 3 Ridgid GEN5X R8653 Base Assembly Replacement: passo 2, immagine 3 di 3
    • Remove seven 6mm T20 Torx screws located around base of saw.
    • Pull base assembly away from saw.
    • These screws are very tight and need significant force to be removed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 218
