Salta al contenuto principale
Ridgid GEN5X R8611506 Light Switch Replacement
Cosa ti serve
  1. Ridgid GEN5X R8611506 Light Switch Replacement, Outer Case: passo 1, immagine 1 di 2 Ridgid GEN5X R8611506 Light Switch Replacement, Outer Case: passo 1, immagine 2 di 2
    • Orient the drill to have the side with the screws facing up.
    • Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
  2. Ridgid GEN5X R8611506 Light Switch Replacement: passo 2, immagine 1 di 3 Ridgid GEN5X R8611506 Light Switch Replacement: passo 2, immagine 2 di 3 Ridgid GEN5X R8611506 Light Switch Replacement: passo 2, immagine 3 di 3
    • Orient the drill to where the back is facing up.
    • Using a Torx T10 screwdriver, remove the four 6.0mm screws that attach the back piece to the drill.
    • Remove the back piece of the drill using the iFixit opening tool.
  3. Ridgid GEN5X R8611506 Light Switch Replacement: passo 3, immagine 1 di 2 Ridgid GEN5X R8611506 Light Switch Replacement: passo 3, immagine 2 di 2
    • Orient the drill to where the chuck is facing up.
    • Using the Torx T15 screwdriver, remove the four 8.0mm screws from the front of the drill.
  4. Ridgid GEN5X R8611506 Light Switch Replacement: passo 4, immagine 1 di 2 Ridgid GEN5X R8611506 Light Switch Replacement: passo 4, immagine 2 di 2
    • Orient the drill so the side with the screw holes is facing up.
    • Use a plastic opening tool to gently pry the face off of the drill.
    • Remove the face completely from the drill.
  5. Ridgid GEN5X R8611506 Light Switch Replacement, Light Switch: passo 5, immagine 1 di 2 Ridgid GEN5X R8611506 Light Switch Replacement, Light Switch: passo 5, immagine 2 di 2
    • Locate the light switch near the bottom of the drill's inner components.
    • Gently remove the light switch from the casing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 366
