Salta al contenuto principale
Ridgid Circular Saw R3205 Spindle Lock Replacement
Cosa ti serve
  1. Ridgid Circular Saw R3205 Spindle Lock Replacement, Blade: passo 1, immagine 1 di 2 Ridgid Circular Saw R3205 Spindle Lock Replacement, Blade: passo 1, immagine 2 di 2
    • Press the black spindle lock and hold it down.
    • While keeping the spindle lock pressed down use a 6mm allen wrench to remove the 5/16-18 x 0.55 inch screw.
  2. Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 2, immagine 1 di 1
    • Release the spindle lock and remove the outer flange by lifting it off the output shaft.
  3. Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 3, immagine 1 di 3 Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 3, immagine 2 di 3 Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 3, immagine 3 di 3
    • With the outer flange removed retract the lower blade guard into the upper blade guard housing by pushing on the black lever.
    • Slide the blade out of from the bottom of the saw.
  4. Ridgid Circular Saw R3205 Spindle Lock Replacement, Lower Blade Guard: passo 4, immagine 1 di 2 Ridgid Circular Saw R3205 Spindle Lock Replacement, Lower Blade Guard: passo 4, immagine 2 di 2
    • Use a prying tool or your fingers to remove the inner flange.
  5. Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 5, immagine 1 di 3 Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 5, immagine 2 di 3 Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 5, immagine 3 di 3
    • Remove the external retaining ring with a screwdriver by expanding it and then prying it out.
  6. Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 6, immagine 1 di 1
    • After removing the external retaining ring, remove (OD50 x ID42 x 0.8t) washer.
  7. Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 7, immagine 1 di 2 Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 7, immagine 2 di 2
    • Remove the lower blade guard after removing the washer.
  8. Ridgid Circular Saw R3205 Spindle Lock Replacement, Spindle Lock: passo 8, immagine 1 di 1
    • Remove the (M3 x 12 mm) screw using a phillips head screwdriver.
  9. Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 9, immagine 1 di 1
    • Leave the rubber dust cover below the removed screw.
  10. Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 10, immagine 1 di 3 Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 10, immagine 2 di 3 Ridgid Circular Saw R3205 Spindle Lock Replacement: passo 10, immagine 3 di 3
    • Pull out the Spindle Lock.
Conclusione
Joshua Caron
Membro da: 04/05/19
792 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,480
