Salta al contenuto principale
Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement
Cosa ti serve
  1. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: passo 1, immagine 1 di 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: passo 1, immagine 2 di 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: passo 1, immagine 3 di 3
    • Remove the brush assembly with a flat head screwdriver.
  2. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: passo 2, immagine 1 di 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: passo 2, immagine 2 di 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: passo 2, immagine 3 di 3
    • Use a T25 Torx screwdriver to remove 3 (M5 x 58 mm) screws.
  3. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: passo 3, immagine 1 di 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: passo 3, immagine 2 di 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: passo 3, immagine 3 di 3
    • Use a T20 Torx screwdriver to remove the (1/4-20 x 0.66 in.) screw.
    • After removing the (1/4-20 x 0.66 in.) screw the lever assembly can be unscrewed from the (1/4-20 x 0.66 in.) screw.
  4. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: passo 4, immagine 1 di 2 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: passo 4, immagine 2 di 2
    • The motor housing assembly can now be removed from the rest of the saw.
Conclusione
Joshua Caron
Membro da: 04/05/19
792 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 362
