Introduzione
The blade on a circular saw is one of the most commonly replaced items. The blade wears down the quickest and needs to be replaced when the saw isn’t making cuts as effectively, the blade has broken teeth, or if the blade is bent. Replacing the blade doesn’t require any complicated steps.
Cosa ti serve
Press the black spindle lock and hold it down.
While keeping the spindle lock pressed down use a 6mm allen wrench to remove the 5/16-18 x 0.55 inch screw.
Altre 2 persone hanno completato questa guida.
