Salta al contenuto principale
Ridgid Angle Grinder R10202 Motor Housing Replacement
Cosa ti serve
  1. Ridgid Angle Grinder R10202 Motor Housing Replacement, Carbon Brush: passo 1, immagine 1 di 2 Ridgid Angle Grinder R10202 Motor Housing Replacement, Carbon Brush: passo 1, immagine 2 di 2
    • Use a flathead screwdriver to unscrew the brush holder cap.
  2. Ridgid Angle Grinder R10202 Motor Housing Replacement: passo 2, immagine 1 di 2 Ridgid Angle Grinder R10202 Motor Housing Replacement: passo 2, immagine 2 di 2
    • Using your fingers, gently lift the carbon brush up and out of its housing.
    • Repeat these steps to remove the other carbon brush on the opposing side.
  3. Ridgid Angle Grinder R10202 Motor Housing Replacement, Motor Housing: passo 3, immagine 1 di 1
    • Unscrew the side handle assembly from the gear housing assembly by hand.
  4. Ridgid Angle Grinder R10202 Motor Housing Replacement: passo 4, immagine 1 di 1
    • Unscrew the clamp nut and the backing flange from the output shaft assembly.
    • You can do this by hand or use a spanner wrench which should be provided in the manufacturers box.
  5. Ridgid Angle Grinder R10202 Motor Housing Replacement: passo 5, immagine 1 di 2 Ridgid Angle Grinder R10202 Motor Housing Replacement: passo 5, immagine 2 di 2
    • Push in the guard lever and twist the guard until it aligns with the slots on the output shaft assembly.
    • There are two arrows that should align before you attempt to pull the pieces apart.
  6. Ridgid Angle Grinder R10202 Motor Housing Replacement: passo 6, immagine 1 di 1
    • Lift the guard away from the output shaft assembly.
  7. Ridgid Angle Grinder R10202 Motor Housing Replacement: passo 7, immagine 1 di 2 Ridgid Angle Grinder R10202 Motor Housing Replacement: passo 7, immagine 2 di 2
    • Using a T25 Torx screwdriver, unscrew the four M5 X 28mm Torx screws.
  8. Ridgid Angle Grinder R10202 Motor Housing Replacement: passo 8, immagine 1 di 3 Ridgid Angle Grinder R10202 Motor Housing Replacement: passo 8, immagine 2 di 3 Ridgid Angle Grinder R10202 Motor Housing Replacement: passo 8, immagine 3 di 3
    • Grab the handle assembly and the gear housing assembly and gently pull apart.
    • Slowly pull the gear housing assembly out being careful not to damage the motor against the inside of the motor housing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 838
