Salta al contenuto principale
Ridgid Angle Grinder R10202 Disk Guard Spring Replacement
Cosa ti serve
  1. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement, Disk Guard Spring: passo 1, immagine 1 di 1
    • Unscrew the clamp nut and the backing flange from the output shaft assembly.
    • You can do this by hand or use a spanner wrench which should be provided in the manufacturers box.
  2. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: passo 2, immagine 1 di 2 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: passo 2, immagine 2 di 2
    • Push in the guard lever and twist the guard until it aligns with the slots on the output shaft assembly.
    • There are two arrows that should align before you attempt to pull the pieces apart.
  3. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: passo 3, immagine 1 di 2 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: passo 3, immagine 2 di 2
    • Unscrew the 5 M5 X 10mm screws using a Torx T20 Bit.
    • Carefully separate the spacer from the guard.
  4. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: passo 4, immagine 1 di 2 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: passo 4, immagine 2 di 2
    • Gently push the spring away from the spacer.
    • The spacer, spring, and guard lever should now be all separate.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 723
