Salta al contenuto principale
Ricoh YF-20 Super Lens Cover Replacement
Cosa ti serve
  1. Ricoh YF-20 Super Lens Cover Replacement, Front Cover: passo 1, immagine 1 di 2 Ricoh YF-20 Super Lens Cover Replacement, Front Cover: passo 1, immagine 2 di 2
    • Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
  2. Ricoh YF-20 Super Lens Cover Replacement: passo 2, immagine 1 di 3 Ricoh YF-20 Super Lens Cover Replacement: passo 2, immagine 2 di 3 Ricoh YF-20 Super Lens Cover Replacement: passo 2, immagine 3 di 3
    • Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
    • The lid of the battery compartment may fall off because it is not attached to anything.
  3. Ricoh YF-20 Super Lens Cover Replacement: passo 3, immagine 1 di 3 Ricoh YF-20 Super Lens Cover Replacement: passo 3, immagine 2 di 3 Ricoh YF-20 Super Lens Cover Replacement: passo 3, immagine 3 di 3
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
  4. Ricoh YF-20 Super Lens Cover Replacement: passo 4, immagine 1 di 3 Ricoh YF-20 Super Lens Cover Replacement: passo 4, immagine 2 di 3 Ricoh YF-20 Super Lens Cover Replacement: passo 4, immagine 3 di 3
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
  5. Ricoh YF-20 Super Lens Cover Replacement: passo 5, immagine 1 di 2 Ricoh YF-20 Super Lens Cover Replacement: passo 5, immagine 2 di 2
    • Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
  6. Ricoh YF-20 Super Lens Cover Replacement: passo 6, immagine 1 di 3 Ricoh YF-20 Super Lens Cover Replacement: passo 6, immagine 2 di 3 Ricoh YF-20 Super Lens Cover Replacement: passo 6, immagine 3 di 3
    • Loosen the front cover from the left and right sides of the camera.
    • Take off the front cover.
  7. Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: passo 7, immagine 1 di 3 Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: passo 7, immagine 2 di 3 Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: passo 7, immagine 3 di 3
    • The lens cover is only attached to the front cover of the camera. Set the rest of the camera aside.
    • In order to reach the lens cover, the zoom mechanism must be removed.
    • Unscrew three screws from the front cover that hold the zoom mechanism in place.
    • Remove the zoom mechanism.
  8. Ricoh YF-20 Super Lens Cover Replacement: passo 8, immagine 1 di 3 Ricoh YF-20 Super Lens Cover Replacement: passo 8, immagine 2 di 3 Ricoh YF-20 Super Lens Cover Replacement: passo 8, immagine 3 di 3
    • Unscrew the five screws that hold the lens cover plate and metal brace in place.
    • Remove metal brace.
    • Remove lens cover plate.
  9. Ricoh YF-20 Super Lens Cover Replacement: passo 9, immagine 1 di 2 Ricoh YF-20 Super Lens Cover Replacement: passo 9, immagine 2 di 2
    • To remove lens cover, push the lens cover from the outside of the front cover towards the inside of the front cover.
    • Remove the lens cover.
    • The metal arm attached to the lens cover is not securely attached and may fall off.
Conclusione
Eric Dazet
Membro da: 04/10/12
352 Reputazione
5 Guide realizzate
Cal Poly, Team 6-21, Amido Spring 2012 Membro di Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 335
