Salta al contenuto principale
Ricoh YF-20 Super Front Cover Replacement
Cosa ti serve
  1. Ricoh YF-20 Super Front Cover Replacement, Front Cover: passo 1, immagine 1 di 2 Ricoh YF-20 Super Front Cover Replacement, Front Cover: passo 1, immagine 2 di 2
    • Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
    Chiedi a FixBot
  2. Ricoh YF-20 Super Front Cover Replacement: passo 2, immagine 1 di 3 Ricoh YF-20 Super Front Cover Replacement: passo 2, immagine 2 di 3 Ricoh YF-20 Super Front Cover Replacement: passo 2, immagine 3 di 3
    • Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
    • The lid of the battery compartment may fall off because it is not attached to anything.
    Chiedi a FixBot
  3. Ricoh YF-20 Super Front Cover Replacement: passo 3, immagine 1 di 3 Ricoh YF-20 Super Front Cover Replacement: passo 3, immagine 2 di 3 Ricoh YF-20 Super Front Cover Replacement: passo 3, immagine 3 di 3
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
    Chiedi a FixBot
  4. Ricoh YF-20 Super Front Cover Replacement: passo 4, immagine 1 di 3 Ricoh YF-20 Super Front Cover Replacement: passo 4, immagine 2 di 3 Ricoh YF-20 Super Front Cover Replacement: passo 4, immagine 3 di 3
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
    Chiedi a FixBot
  5. Ricoh YF-20 Super Front Cover Replacement: passo 5, immagine 1 di 2 Ricoh YF-20 Super Front Cover Replacement: passo 5, immagine 2 di 2
    • Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
    Chiedi a FixBot
  6. Ricoh YF-20 Super Front Cover Replacement: passo 6, immagine 1 di 3 Ricoh YF-20 Super Front Cover Replacement: passo 6, immagine 2 di 3 Ricoh YF-20 Super Front Cover Replacement: passo 6, immagine 3 di 3
    • Loosen the front cover from the left and right sides of the camera.
    • Take off the front cover.
    Chiedi a FixBot
Conclusione
Eric Dazet
Membro da: 04/10/12
352 Reputazione
5 guide realizzate
Cal Poly, Team 6-21, Amido Spring 2012 Membro di Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Membri
21 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 52
Tutti i Tempi: 1,007
