Salta al contenuto principale
Ricoh Theta S Outer Case Replacement
Cosa ti serve
  1. Ricoh Theta S Outer Case Replacement, Outer Case: passo 1, immagine 1 di 1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Outer Case Replacement: passo 2, immagine 1 di 2 Ricoh Theta S Outer Case Replacement: passo 2, immagine 2 di 2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
    when doing this careful as the screws do strip
    david.demian - Replica
  3. Ricoh Theta S Outer Case Replacement: passo 3, immagine 1 di 3 Ricoh Theta S Outer Case Replacement: passo 3, immagine 2 di 3 Ricoh Theta S Outer Case Replacement: passo 3, immagine 3 di 3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
    thank you for the instructions. Keep in mind that the Spring clips are just on the other side of the phone, the side without the photo button. Then metal casing is attached to the front and can bend easy. So be careful here. If you get a red light, 5 beeps, and the device turns off, it means you’ve got a physical error code, and you need to investigate. In my case, I disconnected one of the flex cables to one of the cameras, and this needed to be redone.
Conclusione
IUPUI, Team S3-G1, Harley Fall 2017 Membro di IUPUI, Team S3-G1, Harley Fall 2017
IUPUI-HARLEY-F17S3G1
3 Membri
4 Guide realizzate
Un commento
Where can find spare part case?
Thanks
Franco - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,115
