Salta al contenuto principale
Ricoh Theta S Outer Case Replacement
Cosa ti serve
  1. Ricoh Theta S Outer Case Replacement, Outer Case: passo 1, immagine 1 di 1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Outer Case Replacement: passo 2, immagine 1 di 2 Ricoh Theta S Outer Case Replacement: passo 2, immagine 2 di 2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Outer Case Replacement: passo 3, immagine 1 di 3 Ricoh Theta S Outer Case Replacement: passo 3, immagine 2 di 3 Ricoh Theta S Outer Case Replacement: passo 3, immagine 3 di 3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
Conclusione
IUPUI, Team S3-G1, Harley Fall 2017 Membro di IUPUI, Team S3-G1, Harley Fall 2017
IUPUI-HARLEY-F17S3G1
3 Membri
4 Guide realizzate
Un commento
Where can find spare part case?
Thanks
Franco - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,108
