Salta al contenuto principale
Ricoh Theta S Internal microSD Replacement
Cosa ti serve
  1. Ricoh Theta S Internal microSD Replacement, Outer Case: passo 1, immagine 1 di 1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Internal microSD Replacement: passo 2, immagine 1 di 2 Ricoh Theta S Internal microSD Replacement: passo 2, immagine 2 di 2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Internal microSD Replacement: passo 3, immagine 1 di 3 Ricoh Theta S Internal microSD Replacement: passo 3, immagine 2 di 3 Ricoh Theta S Internal microSD Replacement: passo 3, immagine 3 di 3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
  4. Ricoh Theta S Internal microSD Replacement, Battery: passo 4, immagine 1 di 2 Ricoh Theta S Internal microSD Replacement, Battery: passo 4, immagine 2 di 2
    • The battery is located near the bottom of the device.
    • Flip the plastic containing thermal compound over so it is resting on top of the battery.
  5. Ricoh Theta S Internal microSD Replacement: passo 5, immagine 1 di 2 Ricoh Theta S Internal microSD Replacement: passo 5, immagine 2 di 2
    • Lift the battery out of the device, beginning with the end closest to the camera.
  6. Ricoh Theta S Internal microSD Replacement, Internal microSD: passo 6, immagine 1 di 1
    • Remove the two 2mm Phillips screws.
    • Remove the black 2mm Phillips screw.
    • Remove the 1.5mm Phillips screw.
  7. Ricoh Theta S Internal microSD Replacement: passo 7, immagine 1 di 3 Ricoh Theta S Internal microSD Replacement: passo 7, immagine 2 di 3 Ricoh Theta S Internal microSD Replacement: passo 7, immagine 3 di 3
    • Carefully pull the side casing away from the camera.
  8. Ricoh Theta S Internal microSD Replacement: passo 8, immagine 1 di 3 Ricoh Theta S Internal microSD Replacement: passo 8, immagine 2 di 3 Ricoh Theta S Internal microSD Replacement: passo 8, immagine 3 di 3
    • Lift up the plastic containing thermal compound to reveal the thermal tape covering the motherboard.
    • Peel back the lower left corner of the thermal tape to reveal the microSD slot located on the motherboard.
  9. Ricoh Theta S Internal microSD Replacement: passo 9, immagine 1 di 2 Ricoh Theta S Internal microSD Replacement: passo 9, immagine 2 di 2
    • Push the microSD card inward, from the side.
    • Once a click is heard, pull the screwdriver away to eject the microSD card from the slot.
Conclusione
IUPUI, Team S3-G1, Harley Fall 2017 Membro di IUPUI, Team S3-G1, Harley Fall 2017
IUPUI-HARLEY-F17S3G1
3 Membri
4 Guide realizzate
8 Commenti
I was able to complete this however there is a clear plastic guard running around the bottom half of the Theta S, and the only way to get the SD Card above that guard was to remove a few additional screws. Fortunately was not that complex and reassembly was still successful. Good luck!
jason - Replica
Maximum size of SD Card? 128GB?
just - Replica
I’ve not heard of anyone getting anything over 32gb to work, but I don’t think that’s definitive, as, even with 32GB cards, some would work and some wouldn’t. I think I might order a 64gb and try it out…
Basil Yokarinis -
I successfully replaced my microSD card with a transcend 32gb card, and it’s working. Only thing is, I ended up with 2 tiny braided wire sleeves that fell out during the process, and I have no idea where they are supposed to be. Also, before the repair, I had, an error come up at random and stop interval shooting (while there was still space available and power):
_cameraError":[“FORMAT_CARD”]
Now, after the repair, the error is:
_cameraError":["FORMAT_INTERNAL_MEM"]
And it’s constant, but, aside from causing the red lamp to blink always, and also beeping when I turn it on, it doesn’t seem to affect the function of the camera.
One point to improve the tutorial would be in step 8, in the 3rd picture, there’s a metallic, odd shaped piece sitting at an angle in the picture. This piece fell out when I was working to replace the microSD card, and I had to search other tutorials to figure out where it had to go.
Basil Yokarinis - Replica
Correction, it was a Sandisk Ultra
Basil Yokarinis -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 38
Tutti i Tempi: 3,947
