Salta al contenuto principale
Introduzione
Follow this guide to replace the battery of your Ricoh Theta S. Be aware that any replacement of disassembly of the original product may void the manufacturer warranty.
Parti
Nessuna parte specificata.
  1. Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Use a Phillips #00 screwdriver to remove the four 3-mm screws located on the bottom of the device. Use a Phillips #00 screwdriver to remove the four 3-mm screws located on the bottom of the device.
    • Use a Phillips #00 screwdriver to remove the four 3-mm screws located on the bottom of the device.
    when doing this careful as the screws do strip
    david.demian - Replica
  3. Kits di riparazione iPhone X
    Garanzia finita? Non preoccuparti, abbiamo la soluzione.
    Acquista ora
    Acquista ora
  4. Insert the plastic opening tool in between the panels shown. Apply pressure to unlatch the 9 spring clips located around the perimeter of the device. Lift the panel from the device.
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
    thank you for the instructions. Keep in mind that the Spring clips are just on the other side of the phone, the side without the photo button. Then metal casing is attached to the front and can bend easy. So be careful here. If you get a red light, 5 beeps, and the device turns off, it means you’ve got a physical error code, and you need to investigate. In my case, I disconnected one of the flex cables to one of the cameras, and this needed to be redone.
  5. The battery is located near the bottom of the device. Flip the plastic containing thermal compound over so it is resting on top of the battery.
    • The battery is located near the bottom of the device.
    • Flip the plastic containing thermal compound over so it is resting on top of the battery.
  6. Lift the battery out of the device, beginning with the end closest to the camera. Lift the battery out of the device, beginning with the end closest to the camera.
    • Lift the battery out of the device, beginning with the end closest to the camera.
Conclusione
Bradley Sutton
Membro da: 07/11/2017
485 Reputazione
4 Guide realizzate
IUPUI, Team S3-G1, Harley Fall 2017 Membro di IUPUI, Team S3-G1, Harley Fall 2017
IUPUI-HARLEY-F17S3G1
3 Membri
4 Guide realizzate
Nice demonstration, but if I can’t find a DB-110 replacement battery, I’m not sure if I would take the camera apart. If I find a replacement, this step-by-step demonstration will be very helpful.
Joel Brondos - Replica
The battery replacement for Ricoh Theta S is the Olympus battery model LI-92B.
It’s the perfect equivalent of the original Ricoh DB-110 battery. Tested personally.
Please don’t use any other similar battery or you risk to breaking the charge control circuit of the camera!!
Please note that you nullify the warranty, if the item is under coverage.
Franco - Replica
Do you have a good link for Olympus battery model LI-92B ?
Patrick D - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 123
Tutti i Tempi: 2,233
