Salta al contenuto principale
Ricoh Super 8 800z Film Cartridge Hooks Replacement
Cosa ti serve
  1. Ricoh Super 8 800z Film Cartridge Hooks Replacement, Film Cartridge Hooks: passo 1, immagine 1 di 3 Ricoh Super 8 800z Film Cartridge Hooks Replacement, Film Cartridge Hooks: passo 1, immagine 2 di 3 Ricoh Super 8 800z Film Cartridge Hooks Replacement, Film Cartridge Hooks: passo 1, immagine 3 di 3
    • Open the device's film cartridge door by pulling the release switch towards the eyepiece.
    • Lay the device with the left side down and the door open to allow access to the film cartridge hooks.
  2. Ricoh Super 8 800z Film Cartridge Hooks Replacement: passo 2, immagine 1 di 3 Ricoh Super 8 800z Film Cartridge Hooks Replacement: passo 2, immagine 2 di 3 Ricoh Super 8 800z Film Cartridge Hooks Replacement: passo 2, immagine 3 di 3
    • Using a Phillips #000 screwdriver, remove one of the screws from the rotating hooks in the center of the film bay.
    • Be sure to hold down the opposite side of the hooks with a finger to prevent it from spinning.
  3. Ricoh Super 8 800z Film Cartridge Hooks Replacement: passo 3, immagine 1 di 2 Ricoh Super 8 800z Film Cartridge Hooks Replacement: passo 3, immagine 2 di 2
    • Now put your finger on the side of the screw you just removed, and take out the remaining screw with a Phillips #000 screwdriver.
  4. Ricoh Super 8 800z Film Cartridge Hooks Replacement: passo 4, immagine 1 di 2 Ricoh Super 8 800z Film Cartridge Hooks Replacement: passo 4, immagine 2 di 2
    • Using your fingers, gently remove the film cartridge hooks.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 226
