Salta al contenuto principale
Ricoh Super 8 800z Eyepiece Adjuster Replacement
Cosa ti serve
  1. Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: passo 1, immagine 1 di 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: passo 1, immagine 2 di 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: passo 1, immagine 3 di 3
    • Remove the rubber covering from the eyepiece by slowly pulling down on the cover from any direction.
  2. Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 2, immagine 1 di 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 2, immagine 2 di 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 2, immagine 3 di 3
    • Use Phillips #000 screwdriver to remove the three screws around the eyepiece lens.
    • Remove the metal plate from the eyepiece.
  3. Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 3, immagine 1 di 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 3, immagine 2 di 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 3, immagine 3 di 3
    • Turn the adjustment ring counter clockwise until it is as close to the lens as it will go.
  4. Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 4, immagine 1 di 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 4, immagine 2 di 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 4, immagine 3 di 3
    • Remove the screw on top of the back panel of the camera using a Phillips #000 screwdriver.
    • Use a plastic opening tool to lift the plastic covering to reveal a screw underneath it.
  5. Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 5, immagine 1 di 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 5, immagine 2 di 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 5, immagine 3 di 3
    • Continue to hold the plastic covering back with the plastic opening tool.
    • Use a #1 flathead screwdriver to remove screw in the oval opening beside the eyepiece. Be careful not to drop the screw into the camera body.
  6. Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 6, immagine 1 di 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 6, immagine 2 di 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 6, immagine 3 di 3
    • Slide the eyepiece adjuster out of the camera body.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 286
