Salta al contenuto principale
Ricoh Shotmaster 130Z Zooming Lens Replacement
Cosa ti serve
  1. Ricoh Shotmaster 130Z Zooming Lens Replacement, Zooming Lens: passo 1, immagine 1 di 1
    • Set the dials to "A" (Auto), and Off mode.
    • You will not be able to move these dials once the case has been opened.
  2. Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 2, immagine 1 di 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 2, immagine 2 di 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 2, immagine 3 di 3
    • Remove the 5 Phillips screws from the sides and the back.
  3. Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 3, immagine 1 di 2 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 3, immagine 2 di 2
    • Remove the 5mm JIS #00 screws from the bottom of the camera.
    • Pay attention to the 6mm screws on the sides of the tripod slot, as they are a slightly different size from the rest of the screws. However, you still may use a J00 screwdriver to remove them.
  4. Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 4, immagine 1 di 2 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 4, immagine 2 di 2
    • Using an opening tool, lift the case of the tripod slot (on the bottom) until the back portion of the case is released.
    • Continue to use the the opening tool to insert it and lift right next to the strap of the camera.
    • This will release the front portion of the case.
  5. Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 5, immagine 1 di 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 5, immagine 2 di 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 5, immagine 3 di 3
    • Use a JIS #0 screwdriver to remove the three marked screws found around the perimeter of the lens.
  6. Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 6, immagine 1 di 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 6, immagine 2 di 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Proceed to remove the two screws using a JIS #00 screwdriver.
    • Use tweezers to lift the lens off of the board.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 55
Tutti i Tempi: 885
