Salta al contenuto principale
Revlon RVDR5061 Heating Element Assembly Replacement
Cosa ti serve
  1. Revlon RVDR5061 Heating Element Assembly Replacement, Fan/Motor Assembly: passo 1, immagine 1 di 1
    • Using a Phillips #3 screwdriver, remove the single 25 mm Phillips head screw in the handle by turning it counterclockwise.
  2. Revlon RVDR5061 Heating Element Assembly Replacement: passo 2, immagine 1 di 1
    • Using a medium flathead screwdriver or better yet iFixit plastic opening tools, gently pry apart the handle from the power cord.
  3. Revlon RVDR5061 Heating Element Assembly Replacement: passo 3, immagine 1 di 1
    • After pulling apart the housing, all internals will be free to remove.
  4. Revlon RVDR5061 Heating Element Assembly Replacement: passo 4, immagine 1 di 3 Revlon RVDR5061 Heating Element Assembly Replacement: passo 4, immagine 2 di 3 Revlon RVDR5061 Heating Element Assembly Replacement: passo 4, immagine 3 di 3
    • The fan/motor assembly is connected to the heating element assembly at two points need to be desoldered. After pulling the attached wires through the holes the fan/motor assembly will be free from the heating element assembly. Congratulations you have now completely removed the fan/motor assembly from this hair dryer!
  5. Revlon RVDR5061 Heating Element Assembly Replacement, Heating Element Assembly: passo 5, immagine 1 di 2 Revlon RVDR5061 Heating Element Assembly Replacement, Heating Element Assembly: passo 5, immagine 2 di 2
    • Once the fan/motor assembly is disconnected from the heating element assembly you will see that the heating element assembly is connected to a circuit board by four wires. The color of these wires are grey, black, purple and brown.
  6. Revlon RVDR5061 Heating Element Assembly Replacement: passo 6, immagine 1 di 3 Revlon RVDR5061 Heating Element Assembly Replacement: passo 6, immagine 2 di 3 Revlon RVDR5061 Heating Element Assembly Replacement: passo 6, immagine 3 di 3
    • Desolder these four wires one by one from the circuit board.
  7. Revlon RVDR5061 Heating Element Assembly Replacement: passo 7, immagine 1 di 1
    • The heating element assembly will now be separated from the circuit board and can be replaced with a new one.
Conclusione
Soneil Pitamber
Membro da: 07/11/18
97 Reputazione
1 Guida realizzata
IUPUI, Team S2-G2, Wilson Summer 2018 Membro di IUPUI, Team S2-G2, Wilson Summer 2018
IUPUI-WILSON-SU18S2G2
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 776
