Salta al contenuto principale
Revlon One-Step Hair Dryer Barrel Replacement
Cosa ti serve
  1. Revlon One-Step Hair Dryer Barrel Replacement, Barrel: passo 1, immagine 1 di 1
    • First, remove the pink panels on each side of the handle in order to access the screws.
    • Use the iFixit opening tool to remove the pink panels.
  2. Revlon One-Step Hair Dryer Barrel Replacement: passo 2, immagine 1 di 3 Revlon One-Step Hair Dryer Barrel Replacement: passo 2, immagine 2 di 3 Revlon One-Step Hair Dryer Barrel Replacement: passo 2, immagine 3 di 3
    • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
    • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
    • Next, completely remove the screws out of the dryer handle.
  3. Revlon One-Step Hair Dryer Barrel Replacement: passo 3, immagine 1 di 3 Revlon One-Step Hair Dryer Barrel Replacement: passo 3, immagine 2 di 3 Revlon One-Step Hair Dryer Barrel Replacement: passo 3, immagine 3 di 3
    • Remove the barrel by twisting and pulling it away from the handle of the dryer.
    • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,466
