Salta al contenuto principale
Revlon 473 Heating Element Replacement
Cosa ti serve
  1. Revlon 473 Heating Element Replacement, Shell: passo 1, immagine 1 di 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Heating Element Replacement: passo 2, immagine 1 di 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Heating Element Replacement: passo 3, immagine 1 di 3 Revlon 473 Heating Element Replacement: passo 3, immagine 2 di 3 Revlon 473 Heating Element Replacement: passo 3, immagine 3 di 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Heating Element Replacement, Heating Element: passo 4, immagine 1 di 1
    • The heating element is the group of tightly coiled bronze wires behind the vent hose as well as the silver coils.
    • Make sure that there are no breaks or debris obstructing the wires of the heating element.
  5. Revlon 473 Heating Element Replacement: passo 5, immagine 1 di 1
    • To test the heating element, use a digital multimeter.
    • Set the multimeter to 200 under ACV.
    • Bring the ends of the multimeter toward the two lead wires.
    • If the circuit between the wires is closed, the numbers on the multimeter should keep changing.
    • If the numbers are not changing, replace the heating element.
    • If the circuit is closed, check the thermal cutout.
Conclusione
Jessica Leyva
Membro da: 09/18/12
143 Reputazione
5 Guide realizzate
Cal Poly, Team 1-5, Propen Fall 2012 Membro di Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,876
