Salta al contenuto principale
Revlon 473 Hair Dryer Switch Replacement
Cosa ti serve
  1. Revlon 473 Hair Dryer Switch Replacement, Shell: passo 1, immagine 1 di 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Hair Dryer Switch Replacement: passo 2, immagine 1 di 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Hair Dryer Switch Replacement: passo 3, immagine 1 di 3 Revlon 473 Hair Dryer Switch Replacement: passo 3, immagine 2 di 3 Revlon 473 Hair Dryer Switch Replacement: passo 3, immagine 3 di 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Hair Dryer Switch Replacement, Switch: passo 4, immagine 1 di 1
    • Locate the two switches in the handle of the device.
  5. Revlon 473 Hair Dryer Switch Replacement: passo 5, immagine 1 di 1
    • Set the multimeter to 200 ACV.
  6. Revlon 473 Hair Dryer Switch Replacement: passo 6, immagine 1 di 1
    • Bring the probes toward each switch to test for continuity.
    • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
    • If the meter stays at a set number, the circuit is open, and the switch needs to be replaced.
    • To replace a faulty switch, cut the wires and solder the wires back on to the new switch.
Conclusione
Jessica Leyva
Membro da: 09/18/12
143 Reputazione
5 Guide realizzate
Cal Poly, Team 1-5, Propen Fall 2012 Membro di Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,878
