Introduzione
Clean the head of the hairdryer, including the vent, to prevent the fan from getting clogged. Debris in the fan may cause a rattling noise or cause the fan to stop working.
  1. Before disassembly, make sure that the device is unplugged.
    • Before disassembly, make sure that the device is unplugged.
    • Unscrew the two 17.83 mm black screws located on the handle.
  2. Separate the shell from the main component.
    • Separate the shell from the main component.
    • Make sure that the each piece is free from debris.
    • Continue to pull the components apart.
    • For reassembly, put the silver encasing on before the the black cover.
    • Take the head of the hairdryer and pull the pieces apart.
    • Remove the black vent from the grey cylindrical piece.
    • If there is lint in the vent, use tweezers or a toothbrush to extract it from the vent.
    • This will keep the fan from getting clogged and malfunctioning.
    • Clean the other black vent with a toothbrush.
    • Clean these two components with a paper towel.
Conclusione
Jessica Leyva
Membro da: 18/09/2012
107 Reputazione
5 Guide realizzate
Cal Poly, Team 1-5, Propen Fall 2012 Membro di Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Membri
5 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,135
