Introduzione
Repressurize your reverse osmosis (RO) filter reservoir (water pressure bladder)
Cosa ti serve
Open the main valve to release the pressure from the reservoir/bladder.
Leave this open until you are ready to repressurize the reservoir
Remove the cap from the Schrader valve (or other) and connect an air pump
Most reservoirs have a standard Schrader valve
For a standard Schrader valve, connect a bicycle air pump to the valve stem
Use the air pump to (Gently!) force all of the water from the reservoir
(Gently!) pump your air pump as the water is drained from the reservoir
Continue (Gently!) pumping, to ensure all of the water is emptied from the reservoir.
Easy rule of thumb: if your pump has a built-in pressure gauge, generally avoid more than 10 to 20 PSI
Close off the output valve for the reservoir
For most RO unit reservoirs, this is a ball valve on the top of the reservoir
Release any over-pressure of the reservoir
Use your air pump to repressure the, now empty, reservoir
With the reservoir repressurized to the specified pressure, reopen the ball valve
Your reverse osmosis (RO) water pressure reservoir/bladder should now be repressurized!
