Salta al contenuto principale
Retro-Bit Retro Duo Circuit Board Replacement
Cosa ti serve
  1. Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: passo 1, immagine 1 di 3 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: passo 1, immagine 2 di 3 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: passo 1, immagine 3 di 3
    • With the console on its top, remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Simply remove the sticker before screw removal.
    • Flip the console on its feet. Carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not remove the top casing completely. There is a small LED circuit board connected to the main circuit board.
  2. Retro-Bit Retro Duo Circuit Board Replacement: passo 2, immagine 1 di 3 Retro-Bit Retro Duo Circuit Board Replacement: passo 2, immagine 2 di 3 Retro-Bit Retro Duo Circuit Board Replacement: passo 2, immagine 3 di 3
    • Remove the one 6 mm Phillips #0 LED circuit board screw.
    • Lift the top case and set aside.
  3. Retro-Bit Retro Duo Circuit Board Replacement: passo 3, immagine 1 di 3 Retro-Bit Retro Duo Circuit Board Replacement: passo 3, immagine 2 di 3 Retro-Bit Retro Duo Circuit Board Replacement: passo 3, immagine 3 di 3
    • Remove the 11 screws holding the circuit boards and ports in place.
    • Six 11 mm Phillips #2 holding the circuit boards.
    • Three 12 mm Phillips #2 screws holding the controller ports.
    • Two 7 mm Philllips #2 screws holding the back ports
  4. Retro-Bit Retro Duo Circuit Board Replacement: passo 4, immagine 1 di 3 Retro-Bit Retro Duo Circuit Board Replacement: passo 4, immagine 2 di 3 Retro-Bit Retro Duo Circuit Board Replacement: passo 4, immagine 3 di 3
    • Carefully lift the circuit board while holding either the AV or controller ports. Alternatively, you can hold the circuit board on its edges.
    • Make sure to lift the circuit board completely out of the bottom case.
    • To avoid damage, do not to touch the top or bottom faces of the circuit board.
Conclusione
Truong Vo
Membro da: 09/25/17
320 Reputazione
3 Guide realizzate
USF Tampa, Team S4-G4, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Membri
10 Guide realizzate
Un commento
I hope you show the second part were you replace the 72pin connector. Please include part source.
The 72 pin connector grabs too tightly on the cart.
Thanks.
George Tedrick - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 40
Tutti i Tempi: 2,372
